Re-Wired Radio/Audio system
Posted: March 7th, 2022, 8:02 pm
by Pura Vida
Got my boat with two separate car radios, one in the salon for speakers on the main level - cockpit & interior, and another complete system on the fly bridge with 4 speakers above. Of course, by early season, both radios crapped out.
I bought a new JVC car radio for the salon. Had to solder new connector of course. While doing this, i split each of the 4 speaker outputs using a standard ethernet cable (the ethernet cable has 8 conductors, perfect!).
I ran the ethernet to the flybridge switch - a 4 throw switch at about $1 each. From the switch to the 4 speakers upstairs.
The radio is BT, we usually control via phone - pandora...etc. I have a switch to cut the flybridge audio (in case of an emergency, bad song..whatever).
So now, one radio for the vessel, with captain's kill switch. Easy peasy.
Re: Re-Wired Radio/Audio system
Posted: March 7th, 2022, 10:36 pm
by g36
best wishes for a super boating season.
Posted: March 8th, 2022, 7:36 am
I back into my slip blind, can't see a thing back there. My thoughts for a cheap solution since I need a new stereo anyway is to get a 10" unit and hook up a small backup camera to it. I'm hoping the 10" screen will be big enough to see the dock as I back in.
Ethernet cable seems like an awfully small gauge wire to be using for speaker wire. Curious to see how that works out for you.
Posted: March 8th, 2022, 8:49 am
by Midnightsun
Agreed, much too small, 23 or 24 gauge is what is found in cat 5 or 6 cable. Typically the smallest gauge one uses is for automotive speakers is 18 and 16 for subs. On really powerful units you want to go even bigger.
Posted: March 8th, 2022, 4:34 pm
by Pura Vida
Yep...Would get a C- grade for electrical & audio engineers considering impedance matching, small gauge wire, switched & split circuits - all would be frowned upon in the audio engineering scene...etc. BUT, i will say it works perfectly fine, sounds good on all 8 speakers. Of course we are not blasting 100W of punk rock. No detectable distortion with reasonably volumes of classic rock, and even when Bohemian Rhapsody comes up & the volume is turned up.
The setup is still worth sharing for project ideas & methodology.
