370 Voyager 1993 Propellers
Posted: September 14th, 2018, 7:11 am
by Tim Sperryn
Hi
I'm seeking prop specs for the above boat with Cummins 300's?
ps: great to be part of CYO!
Re: 370 Voyager 1993 Propellers
Posted: September 14th, 2018, 8:40 am
Welcome to the forum.....is the boat new to you ?.....sometimes original prop specs from the factory sea trials could be misleading, especially for older boats that have thousands of pounds more stuff on board.
My guess , e mail Carver with your hull number and engine numbers and they may have the original specs for you.Also maybe someone here with the same combo can help......good luck man...
Posted: September 14th, 2018, 10:13 am
Welcome aboard. Hopefully a nother member with the vessel will chime in.
Posted: September 14th, 2018, 11:56 am
by waybomb
Welcome aboard!
Posted: September 15th, 2018, 12:10 am
by RGrew176
Welcome aboard. Good luck in your propeller search. Good news is someone here will have an answer to your question.
Posted: April 7th, 2021, 10:12 am
by Tim Sperryn
Thanks all, I’m currently unable to contact Carver as I suspect the UK on it’s way to medieval times...!
Posted: April 7th, 2021, 3:54 pm
Tim, try contacting Pat Johnson via email. He should be able to help. Include your hull number in the email:
pjohnson@marquisyachts.com
Posted: April 11th, 2021, 10:49 am
by Cooler
Tim - see my comments under Model Discussion category.
er
Posted: April 12th, 2021, 9:14 am
by Tim Sperryn
Many thanks for the contact!
Tim
