Isolator and Zincs
Posted: April 1st, 2022, 2:46 pm
by schooner
Have a 2001 356 aft-cabin. Do I need to have zincs on my tabs ?
Where is the Galvonic Isolator ?
Re: Isolator and Zincs
Posted: April 1st, 2022, 2:53 pm
by g36
I'm in freshwater with a 97 405. I don't have any sacrificial anodes on my trim tabs. Where are you boating?
Posted: April 1st, 2022, 5:55 pm
If you have a galvanic isolator, they're often mounted behind the breaker panel. It's not a requirement to have anodes on your tabs but it is an option. What do you currently have for anodes?
Posted: April 1st, 2022, 7:18 pm
by Tireless
I boat in fresh water and I do have anodes on my trim tabs. They are mounted on the top side of the tab.
Greg
Posted: April 1st, 2022, 7:27 pm
schooner wrote:Source of the post Have a 2001 356 aft-cabin. Do I need to have zincs on my tabs ?
You should have 2 galvanic isolators, one for each shore power line, wired in the green ground....they are most likely behind the 120vac panel. Depends on where your boat is, we always had anodes on the tabs, the shafts and a divers dream on the transom.
Where do you boat ....fresh water or salt ?
Posted: April 2nd, 2022, 8:05 pm
by V12diablo
On my 2001 356, it is located in the master birth behind the right head board, I do have zincs on my tabs and I am in freshwater.
Jason
Posted: April 3rd, 2022, 1:06 pm
by seaweed
I'm in fresh water and on my 2001 Carver 356 Aft Cabin, I have magnesium anodes on the shafts, tabs and hull.
Use zinc for salt water.
