Carver 450 Voyager for sale
Posted: October 16th, 2022, 9:04 pm
2000 Carver Voyager 450 located in Massachusetts $210,000
2 stateroom and 2 head layout with inside helm and enclosed bridge. This boat is perfect for liveaboards or for long weekend cruising.
450 hp Cummins with 1100 hrs-544 gallon of diesel. New engine water pumps and belts replaced this fall. New engine through hulls 2021. Trim tabs replaced 2019. Fuel injectors replaced and lines cleaned in 2017. Cruises at 18 kts and tops out at 21 kts.
13.5 kw Kohler generator with new battery 2022. New genny water pump 2019.
New house battery 2021. New battery chargers- one in 2021 and one in 2022. Glendenning with new power cord 2021.
Bridge has 2017 electronics and the instrument panal replaced in 2019 . All vinyl replaced 2017 and has helm and seating covers also. Dingy davit with cradle and 600 lbs capacity. Full Canvas for bridge and back cockpit 2018
150 gal of water - hot water heater replaced 2017
80 gal holding tank
Saloon had new 42 ” smart TV 2022 with surround sound. New carpet 2019 and central vac. The sliding glass door trucks were replaced 2022. Lounge pilot house has full instrumentations added in 2017. Pilot chair is electric, 6-way positional. Side door latch replaced 2022.
All 4 ACs replaced in 2021 with the AC relay panel replaced 2022.
New 2 burner stovetop 2021. Vitrofirgo refridgerator 2017
Midship master with ensuite head. New mattress 2018. 32 inch TV 2019. Access to bilge storage. Cedar hanging locker
Foreward stateroom with TV 2017. Cedar hanging locker
80 gal holding tank
. We are in the midst of replacing the carpets so it's quite disorganized {messy}. My number is 508-367-0940. Text me when you're in the area. If we are around, you are welcome aboard.
