Alternator replacement
Posted: December 21st, 2020, 10:04 am
by jsurfwhite
I have a 7.4 L gas mercruiser on a 2000 Carver 356 Aft Deck. The alternator is frozen, locked up, and needs to be replaced. Do I go after-market or OEM? Thanks
Re: Alternator replacement
Posted: December 21st, 2020, 10:32 am
by throwback2
Any shops in your area that can rebuild it?
Posted: December 21st, 2020, 11:47 am
by buster53
Whichever way you go, make sure you are buying a sealed, marine unit
Posted: December 21st, 2020, 1:00 pm
Aftermarket would be fine, provided it is some quality item. I've heard mixed reviews in the Sierra, but wouldn't be that concerned if I had to make the purchase. Especially if you have twin engines, where you can tolerate a failure pretty easily.
That said, my first choice would be a local alternator/starter shop. If it's any good, they know what needs to be done and likely have everything in stock. They also would well know the marine standards. We have a shop locally that I've dealt with for over 40 years, so I'd go with them in a heartbeat. You likely have a similar shop somewhere near you too.
Posted: December 21st, 2020, 5:40 pm
by waybomb
Check out DB Electric.
Posted: February 12th, 2021, 5:00 pm
by jsurfwhite
Update on alternator. OEM part was Mando AC165617. Bought alternator from DB Electric, and installed. Everything fit, and up and running.
