Dock Water Problem
- ShipZone
- Vessel Info: 1986 3207 Aft Cabin
Dock Water Problem
- Vessel Info: 2000 CARVER 456 MY
Full Bridge and aft deck enclosure
Originally purchased in Staten Island
Second owner also purchased in Staten Island in 2012
Now berthed in Toronto Canada
A wonderful and fully appointed luxury yacht. - Location: Toronto Ontario Canada
- Been thanked: 4 times
Re: Dock Water Problem
If you have turned off the dock water, your Bilge pump will take care of the spill. I presume your water tank is empty and has Pink Non Toxic antifeeze in it.
You can access the water line from the outside by unscrewing the Dockside water connector , 4 screws . There should be enough slack in the tubing that you should be able to pull it out to look inside.
Follow that back to the inside and there should be an access hatch nearby .
In my opinion , leave it alone for the rest of the winter and fix it in the spring time.
Bring fresh water to the boat in a big jug ,7 gallons is a lot of water for weekend use. You aren't bathing , you just use it for drinking water and hand washing , correct?
I live aboard year round in Toronto Canada and this last week we had temps as low as minus 6 Fahrenheit .
I have cabin heaters and agitators setup and bilges heated . Engines and genny winterized.
It was a scary week and would not recommend leaving your boat unattended.
I hope that helps you .
Victor
- ShipZone
