Tank Monitor system
Posted: September 26th, 2021, 2:31 pm
I have a new Tech-Edge iSeries tank monitor system. Bought for a project then sold the boat.
It comes with three external tank sensors with the foil tape, but will monitor up to 8 tanks. The other tanks might be able to use an existing sensor or you can get different types of sensors that will work. According to Tech-Edge, it is the ONLY tank monitor tested and approved by the United States Coast Guard. It is NMMA Certified using ABYC® standards. Lots of customizable features in the panel (naming tanks, level calibration, alarms, etc). Retails for $255 but I'd accept $150 plus shipping to a good home.
This model comes with the "water pump" switch option, but you could use that switch for any purpose. There are actually provisions in the panel where you could mount two more similar switches if you desired.
Here is the link on their site for more technical info: https://tankedge.com/products.html
