A/C 1989 3807 Aft
Topic author
Psb58
Vessel Info: 3807 Carver Aft 1987
Has thanked: 2 times
A/C 1989 3807 Aft
Postby Psb58 » May 3rd, 2016, 9:39 pm
I have 3 a/c units. Are there 3 water streams exiting the boat? Or is there just 1?
Been thanked: 601 times
Re: A/C 1989 3807 Aft
Postby tomschauer » May 3rd, 2016, 10:04 pm
I believe 3. usually one pump supplies water to all units and they each have a separate discharge.
Keep in mind many changes could have occurred since 1989.
Are you having a problem?
Washopay
Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers
Has thanked: 23 times
Been thanked: 5 times
Postby Washopay » May 4th, 2016, 6:45 am
There are 3. One is forward off of the starboard bow down near the water level. The other two exit into and then out of both port and starboard exhaust boxes (same place your engines exhaust). You won't see them squirting out but you will hear them trickle. Hope this helps.
Has thanked: 468 times
Been thanked: 1765 times
Postby Viper » May 4th, 2016, 7:33 am
Mine has one discharge at the bow on the starboard side close to the water line. The other two dump on the aft starboard side right at the water line under the chine so you can barely hear or see it which is a great feature IMO. Hate sleeping next to a boat that has a stream of water coming on every 30 minutes.
I've got the version with three exhaust holes on port and starboard sides of the hull. Don't know if there were different builds other than that for this vintage.
Topic author
Psb58
Postby Psb58 » May 4th, 2016, 9:17 pm
Thanks! I believe this helps us. Guess we were missing the other 2 because we couldn't see them. Really appreciate the help.
Postby Viper » May 4th, 2016, 9:42 pm
Do you have the same setup with the three holes on both sides of the hull at the aft end?
Washopay
Postby Washopay » May 7th, 2016, 1:21 pm
Psb58 wrote:Source of the post Thanks! I believe this helps us. Guess we were missing the other 2 because we couldn't see them. Really appreciate the help.
I didn't think I had them either. My dock mate made me get in the water right beside the exhaust ports and witness with my ears the trickle. He was right.
SeaDog3807
Vessel Info: 1988 Carver 3807 Aft Cabin
Dual Helm
Dual Mercruiser 7.4 Blue Water Thunderbolt IV ignition
Direct Drives
Koehler 8.5KW Generator
Postby SeaDog3807 » September 7th, 2018, 12:42 am
Interesting. My boat originally did not have ac and then 3 were installed. All three systems have thru hulls, in a column on port side aft just forward of the engine room bilge thru Hull and exhaust port. They even made the run from foward to aft for the foward system... which I think was horrible. I can’t imagine the original set up of the other cabin and aft stayers running into the xhaust. If someone has a photo or two of that plus where the forward ac one is, it would be much appreciated.
