2000 406 diesel auxiliary fuel tank info
- Summer Place
- Vessel Info: 2000 406 ACMY with Cummins 6BTA's
Any input would be appreciated!
Thanks!
- Has thanked: 469 times
- Been thanked: 1765 times
Re: 2000 406 diesel auxiliary fuel tank info
Do you know how much fuel is in there and how old it might be? Really does boil down to that. When in doubt, take a sample and have it tested or pump it all out and start fresh. The condition of the fuel itself is only half the concern, if there's a lot of water in there from condensation, you don't want any passing through your filters and on to your fuel system. In any case, it's beneficial to have spare filters on board and keep an eye on the Racors (if applicable) to check the condition of the fuel and signs of water.
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
Since you have no idea how old the fuel is, get a fuel polishing/removal guy to check the fuel in your tank. You will immediately know if you have water in the tank and it can be quickly removed. Even without testing the fuel, a good fuel guy can get a good feel of how good the fuel is just from appearance and smell. Nasty looking fuel obviously needs to be removed. Of course, testing may be the best course of action.
Now that you have determined how good or bad your fuel is and you have taken corrective action to remove bad fuel here’s my advice going forward. Always use all three tanks to insure you have good, fresh fuel in all tanks. Best way, say you are taking a 50 mile trip. Use the aux tank to get there and saddle tanks to get home. 2 things happen when you do this. You are turning your fuel over in all 3 tanks and by using the aux tank first, you are lightening your weight load in the ass end of the boat first which gives you a little better weight balance.
- Summer Place
I do have dual racors and the primary filter on the motors.
- Been thanked: 646 times
