Voyager 53 bow thruster
Topic author Malta
Charlieg101
Vessel Info: carver 53 voyager 2001
Postby Charlieg101 » September 17th, 2025, 6:36 am
Hello all, I have a problem with my voyager 53 bow thruster. It works when pushing to port but does not to starboard. I sent down a diver to check if the shear pin on any of the props has broke but they are both good. He said that while one prop ishaft s engaged the other is turning freely so probably a broken gear inside the leg. And here is the problem, my thruster is a QL SP 800 24volt and apparently discontinued. I would like to buy the lower leg of the unit but cannot find one or failing that buy a more modern bow thruster that would fit. Has anyone one here has any advice or had this problem. Any response will be very appreciated. Thank you
Sr. Bacca
Vessel Info: 2005 Carver 466
Re: Voyager 53 bow thruster
Postby Sr. Bacca » September 21st, 2025, 8:55 pm
Hi did you solve your thruster issue. I had the same symptoms on my Stern. My boat is a Carver 46 with those same Volvo discontinued thrusters. My tec is suggesting it’s the solenoid on the thruster so we removed it and took it to a shop. Tested faulty so they are rebuilding the solenoid. Hopefully will test it this week.
Users browsing this forum: No registered users and 40 guests
