Carver 444 CPMY ES help
Posted: June 19th, 2018, 7:59 pm
Hi All,
We recently purchased a 2004 Carver 444 CPMY extended salon. We have been cruising in a sailboat for the past 6 years, prior to that I ran large offshore fishing boats, but I must admit that I am a little green when it comes to some of these systems. We are just getting it ready to set off and have run into a few issues that our surveys did not appear to cover and I am asking for help as the manual doesn't appear to solve my issues.
There are 2 thru hull fittings (silcock) in the aft lazarette on the port side. One is about a 1.25" that I believe runs under the master berth to a waste discharge pump, does that sound right? It is currently stuck / frozen. How is this system used / turned on?
The second is smaller, appears to be above the waterline, further back, needs replaced, is currently open, but I have yet to be able to trace it, any ideas?
Another issue I seem to be having is the faucet in the main galley is not working. The pump is working, all faucets, showers, and the bridge wet bar are working, and the former owner says it was working as did the survey. There was some work done on the engines as a result of the survey, could the technicians accidentally turned something off? I have started to try to trace it back but before I move furniture and get in behind the refrigerator, etc. I thought I would see if anyone has any clues on this one?
Any and all help and advice would be appreciated.
Thank you,
Marc
Thank you,
Marc
