1989 3807 fuel tank replacement
- Matt1989Carver3807
- Has thanked: 13 times
- Been thanked: 3 times
Any help would be greatly appreciated! and where would I get that done?
Matt- San Diego
- Has thanked: 314 times
- Been thanked: 585 times
Re: 1989 3807 fuel tank replacement
- Has thanked: 432 times
- Been thanked: 1595 times
While you're at it, I'd recommend considering tank replacement on the other side as well. Chances are it's just a matter of time before it starts leaking too. Given that it's gasoline, this is something you want to be proactive with and not reactive.
You can try calling or emailing Carver with your hull number and they'll provide you with the tank manufacturer but I've been finding a lot of suppliers from back then are no longer around. I've dealt with these guys a few times. They may even have drawings for your tanks. https://speedytanks.com/
Good luck Matt and keep us posted.
- Has thanked: 257 times
- Been thanked: 1103 times
Oddly enough my previous 1997 boat had the same issue. A year after I sold it the new owner called me to tell me what had occurred which was the filler hose had started to leak. I do not understand how the rubber can deteriorate in a filler hose as it only sees gas when filling up which is not all that often especially up here where the season is only 6 months. I do realize it sees fumes all the time and assume this is what ate away the hose. Must have been something wrong with the rubber used by the manufacturer as this is not normal IMHO. Bet you it was the same brand hose as my previous boat.
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 464 times
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
I replaced the hose immediately and ran it such a way that the radius bend angles were minimized and no low spots between the fill neck and tank.
- Has thanked: 550 times
- Been thanked: 1150 times
Thanks for posting guys...good things to check.
One tip I would like to add....when buying critical hose, like exhaust or fuel fill etc, try to make sure you are buying the freshest hose you can.......ask when they got it/ how old......sometimes this stuff gets to be sitting around in hot dry storage areas and has already started to break down......much like tires.
