Propeller shaft size
Posted: September 17th, 2019, 9:50 pm
by Tim
Can anyone please tell me the propeller shaft diameter on a 1999 Carver 450 Voyager with 450 HP Cummins engines?
Re: Propeller shaft size
Posted: September 18th, 2019, 7:42 am
Some info in the parts manual..... section 13.2 ...check if it is for the right engine...
https://carveryachts.blob.core.windows. ... ual_99.pdf
Posted: September 18th, 2019, 8:46 am
by tomschauer
I personally would not trust the parts manual. I have the original manual that came with my boat when purchased new. It says I have 1 1/2" shafts. They are 1 3/8".
I would measure them to be certain.
Posted: September 18th, 2019, 8:27 pm
Send an email to Carver with your hull number. They'll be able to tell you what they used on your particular build.
Posted: September 19th, 2019, 1:04 am
by Tim
Thanks for the help.
Posted: September 19th, 2019, 2:42 pm
by Davisknd
Hi:
I just purchased a 2000 450 Voyager with Cummins 450's. The shaft diameter noted on my survey is 2-1/4". In the photos they definitely look bigger that 1.5's.
Hope this helps!
