Anchor Roller Worn Out
Postby Midnightsun » June 2nd, 2022, 11:32 am
My anchor rollers were in pitiful shape probably because the rode was all chain which takes a toll on the rollers. I did change my anchor and replaced my rode with 5/16"chain and 9/16" 8 plait rope which is what is required for my windlass and should resolve any more wear issues on the rollers.
Here you can see how the roller basically got cut in half due to wear and the material used was rather brittle. I looked for replacements however finding the correct size (hole diameter & width) was impossible not to mention expensive. Had some type of phenolic material left over at the shop so I machined it to my liking. Yes I have 2 roller on the stock set up. Made them slightly bigger and better shaped IMHO. Will try them out tomorrow and hopefully they work as expected. If not, no big deal, back on the lathe and modify to suit.
Been thanked: 1111 times
Re: Anchor Roller Worn Out
Postby km1125 » June 2nd, 2022, 11:37 am
Cool project!! Good luck on the results!
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » June 2nd, 2022, 4:55 pm
Nice!!!!!!!!!! Same but not exactly in that shape. I mean, mine are not split in 2 but worn. Tell me, are you going to produce these for like, friends????? 8-)
Users browsing this forum: No registered users and 46 guests
