3207 Hynautic steering gone bad
- Six7390GT
- Vessel Info: 1984 3207 Twin 5.8 GT40 Fords
- Has thanked: 3 times
- Has thanked: 60 times
- Been thanked: 980 times
Re: 3207 Hynautic steering gone bad
- Six7390GT
A little history, we've had this boat since 1998. We moved into another older house about 10 years ago, and up until then this boat was our baby, we were out on it as much as possible, we've made countless trips to the Gulf Islands on it from the Seattle area, but it has not seen a lot of use since then. I'm pretty good about keeping up with the normal maintenance, changing oil and fuel filters, keeping up on the cooling and exhaust systems, and we spend nights on the boat at our marina, but the boat hasn't been out much for several years.
Before I disconnected the hydraulic ram, I cycled the steering lock to lock about 30 times and it seemed to loosen up a bit. The wheel is also turning to starboard nearly normally now, but turning to port is noticeably more difficult, and the helm pump makes more noise in that direction.
I'm thinking that hooking the cylinder back up and cycling lock to lock many more times might be what it needs. But I would certainly appreciate any good advice to help loosen the rudders/steering up.
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 401 times
The air in the reservoir only pushes the fluid up to the helms, which are the pumps that move the fluid that moves the piston in the ram. The air has no effect on steering force.
With the ram disconnected. Does the steering work freely?
- Six7390GT
waybomb wrote:Source of the post Do I understand correctly, with the ram disconnected, the rudders are very difficult to move? There should be some resistance, but you should also be able to move them.
Thanks for your reply. Yes, the rudders are very difficult to move - possibly from lack of use for several years? I do start the engines at least every other week, and I always move the steering lock to lock a few times while the engines are running.
- Six7390GT
I tried to post a couple of pics of Choices that I took earlier in the week, but wasn't sure how to post them. Do I need to have them stored online somewhere? With the GT40 marine engines, fresh bottom paint and props she'll run 32 knots - if you can afford the gas.
Six7390GT wrote:Source of the post Thanks for the reply. The boat sits under cover in salt water, we're in the Seattle area. We have our divers out every 6 months to do hull scrubbing and zincs. They serviced our boat earlier in the week and said everything looked good. The rudders have standard stuffing boxes and have flax packing in them. I have some kroil penetrating oil I thought I might use to try to loosen up the rudder shafts. If anyone has a suggestion for a different lube please let me know.
If they're on your computer, just upload them like this:
- Six7390GT
Users browsing this forum: Google [Bot] and 20 guests
