86 Mariner 3697 steering issue
Has thanked: 60 times
Been thanked: 479 times
Re: 86 Mariner 3697 steering issue
Postby waybomb » October 27th, 2025, 5:09 pm
I'd try and fix what I have. When the piston is fully retracted. Is the broken part still external? I'm guessing it is. Get a ship to fabricate a stub and weld it on with the piston fully extended. Someone that had welding certs, not just anybody with a welder
MrMojoRisin
Vessel Info: 1986 Carver Mariner 3697
Has thanked: 17 times
Postby MrMojoRisin » October 27th, 2025, 5:19 pm
Yeah I thought about that but I think the shaft might be bent as well. I think it’s hard to see in the photo, but it looks like that internal shaft has a pretty significant bend and I’m not sure if that can be straightened. I’ll get it out this weekend and take a closer look.
Thanks,
Eric
2012 Larson FX1850
Has thanked: 467 times
Been thanked: 1763 times
Postby Viper » October 27th, 2025, 5:55 pm
You only want to do this once, right? Get another cylinder.
MrMojoRisin
Postby MrMojoRisin » October 28th, 2025, 10:12 am
Does anyone know if this is a K-19 or a k-18? I've just learned there two similar units with the only difference being the stroke length. k-19 is 9", while the k-18 is 7". I didn't think to measure it when i was there this past weekend, and never thought to get a picture of the label itself. Just thought if someone knew i could get the ball rolling.
Thanks,
Eric
2012 Larson FX1850
Users browsing this forum: No registered users and 75 guests
