Norcold DE-251E
USAFRet
Topic author - Scurvy Dog
- Vessel Info: 1993 280 Express
5.7Ltr Penta DuoProp - Location: Watkins Glen, NY
Norcold DE-251E
Around the evening we were plugged in again, and it was working without the cycling I mentioned earlier, so I swapped over to DC. After an hour, I verified the fridge was still working in that mode (the freezer plate was cold), and then placed it back to AC power.
The next day it was dead, other than a few pathetic attempts to kick on, then off.
I'll have a refrigerator tech check it out in a couple weeks, and can survive on coolers for the time being. I started pricing similar capacity units on the off chance the repair isn't economical, but don't see anything for cheaper than a grand or so. OUCH.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Norcold DE-251E
SeaDragon
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
Re: Norcold DE-251E
Steve
USAFRet
Re: Norcold DE-251E
Purchase an AC only fridge (4-6cf.) I think the operating amperage is 1.4, or wattage should be less than 200), and power it with a 420 watt inverter that is powered by my cockpit 12v outlet while we are underway. Do you guys see any train wrecks with this approach?
- AaHubb
Re: Norcold DE-251E
SeaDragon
- Been thanked: 490 times
Re: Norcold DE-251E
You can do better than 1000.
Mkemper
- Vessel Info: 86' carver 3207 Aft
[IMG]http://i1238.photobucket.com/albums/ff498/mjkkemper/null_zps98e8d64b.jpg[/IMG] - Been thanked: 8 times
Re: Norcold DE-251E
http://bryantrv.com/docs2/docs/ncolddedc.pdf
Just fixed mine in that the thermostat when out. I could not find a replacement so I installed two from grander @ $16. One on the 110v the other on the 12v side. Right now I am running it on 12v because the chatter control when out. (Need to order a new one)
Re: Norcold DE-251E
Users browsing this forum: No registered users and 73 guests
