Boat polish or paint?
Posted: May 27th, 2015, 1:00 pm
by jaybla812
Ahoy:
I own a 1989 Carver Monterey cabin cruiser.
The last couple of years the shine has faded more and more especially on the long blue strip along the sides.
I have tried several polishes and recently a rubbing compound with no luck. Last year I took it to an auto body shop, which helped for a while but still faded after a few weeks on the water.
I just can't get the color to "pop" like it used to.
All suggestions would be appreciated.
Re: Boat polish or paint?
Posted: May 27th, 2015, 8:59 pm
by waybomb
Need to go to a marina that knows how to do this.
They will wet sand with a 600 and then maybe a 2000, then do a 3m perfect-it #1 (or similar heavy oxidation compound) with a Makita-type machine buffer, then #2, then a fine polish, and then a wax.
Or a similar procedure. My 36 went 11 years out in the weather untreated and unused and was severely chalked. I used 2000 wet sand, then Perfectit 1, 2, then 3m marine heavy oxidation restorer, and then a swirl remover, and finally covered it with a polymer. Looks like new. Many hours with that Makita buffing machine.
Posted: May 28th, 2015, 8:56 pm
by BobWaz
There is a product called Vert Glass. The process is in I believe 4 steps. It is labor intense. If you specifically follow the directions, it will give great results. I had used this on the black on my Mastercraft.
Posted: May 29th, 2015, 6:37 am
by Ramsport47
DO NOT USE VERT GLASS!!!!! It will start peeling off regardless if you do it properly or not!
Posted: May 29th, 2015, 8:18 am
by BobWaz
Vert Glass....As I said, specifically follow instructions. I re did my Mastercraft about 5 years later, then sold it. Had 2 friends that used it. One came out horrible, the other great and loves it.
Posted: June 9th, 2015, 11:10 am
by After Taxes
Hi.
Highly recommend you do the wet sand method as Waybomb suggested. I did that to a very sun-dulled 1989 Doral Montecello, but it looked showroom new afterwards. When I replaced the top, and with the hull shining, so many people asked me if it was a new boat. After this method, it was extremely easy to keep up appearances with normal waxing.
Go the wet sand method. You will be absolutely satisfied!
Respectfully,
Steve
