propeller sizing
Posted: July 16th, 2016, 1:08 pm
I've got a Carver 390 with twin Cummins 315 HP engines and 4 blade 23x28 props. I recently sent in the props for balancing and the prop shop said the specs given for HP, WOT(2800), gear ratio (1.96:1) and expected speed (21 kn) didn't add up. On sea trials we achieved 2750 rpms and a speed of 40 KPH (21+ knt). Prop shop claimed that those props should not be pitched higher than 23, so they didn't do anything to them awaiting clarification on the numbers I provided on the spec sheet. It seems to me that the props were performing as expected per Carver for this hull. My question is to any other 390 owners with same engines and 23" diameter, 4-blade props, what do you have your props pitched at and what speed do you achieve at WOT?
thanks in advance
Joe
Pacific Horizons
thanks in advance
Joe
Pacific Horizons
