1987 Carver Montego Sea Strainer Location
Posted: June 10th, 2017, 2:57 pm
by 1987CarverMontego
We are new owners of a 1987 Carver Montego 3257 and cannot locate the sea strainer for the engines or ac unit. We easily found the generator sea strainer and cleaned it out but cannot locate the other 3. Please help!
Re: 1987 Carver Montego Sea Strainer Location
Posted: June 10th, 2017, 6:37 pm
Is the thru-hull visible and the hose from the thru-hull to the raw water pump?
It should be in that line.. .but if not you might not have one. Mine didn't come with ones from the factory.
Posted: June 11th, 2017, 1:17 am
Not all models of earlier vintages had strainers installed for the engines. I don't think I've run across an AC install without one though.
