Page 1 of 2
FM Antenna location and type?
Posted: June 26th, 2017, 9:07 am
by amanphoto
Just a quick question. Where is the FM antenna from the radio mounted in the salon? What kind of antenna is it?
Re: FM Antenna location and type?
Posted: June 26th, 2017, 9:22 am
The one in ours appears to be original and is just one of those antennae wires, and is hanging behind the entertainment centre ...I couldn't find anything else.......
Posted: June 27th, 2017, 4:28 am
by RGrew176
That is what most boats seem to have for a radio AM/FM antenna. I have only seen a few boats that have an actual antenna.
Posted: June 28th, 2017, 10:55 am
by AaHubb
Mine has a 3ft whip mounted on the port side of the fly bridge. I assumed it is a factory install but don't know for sure.
..Aaron
Posted: June 28th, 2017, 12:24 pm
by waybomb
I have an 8' Shakespeare fm antenna on the other side of the arch from the vhf antenna. If for no other reason, to keep the vessel symmetrical in appearance
Posted: June 28th, 2017, 9:20 pm
by amanphoto
Has anyone had luck putting a VHF antenna splitter in? Does is degrade the VHF performance?
https://www.westmarine.com/buy/shakespe ... ecordNum=1
Posted: June 28th, 2017, 11:00 pm
by tomschauer
I also have a 3' fm antenna on the port side of the bridge, seems to be factory as the wire is bundled with the rest.
I used an identical band splitter on a previous boat. I didn't notice any change in VHF performance, however, if I had the vhf and the radio on, I would often hear the vhf through the radio speakers. It seemed this only happened with a strong local vhf signal.
Posted: June 30th, 2017, 11:59 am
by SplashyLady
I don't recommend a splitter - seem to impact performance both ways. If you are in a very remote area, consider a small amplified antenna mounted somewhere in the cabin (even behind a panel is OK). Terk makes a good one and one I currently have uses a 12vDC power supply:
http://www.ebay.com/itm/Terk-Tower-Indo ... SwDNdVpp2p
Posted: July 6th, 2017, 11:21 pm
by Lyndon670
I had the splitter on my Silverton 42C, and had no problems. I am about to order one for my 506.
Posted: July 26th, 2017, 10:43 pm
by tomschauer
Lyndon, did you order your splitter?
If not let me know, while cleaning the garage I found a shakespeare 4357s splitter. Brand new never used. I am bit AR and usually buy two of everything.
If interested you can have it for $30.00 plus shipping at cost, probably about $6.
Let me know
Tom
