Need some help with a Davit....
Posted: July 12th, 2021, 1:23 pm
My 2000 Carver 396 has this tilt up davit.
When I purchased the boat last summer it had a 8' rib with an 8hp merc. It was in terrible shape so I found a 11' Rendova with with a 25hp Honda. I picked it up and I have been really happy with it. One issue.... I didn't even think about weight. It is exceptionally heavy. It is difficult to say exactly what it weighs because Rendova information is difficult to find but my estimation is about 700-750lbs wet weight.
This isn't mine, but it is the same tender....
https://boats-from-usa.com/sites/default/files/boats/not-specified/127921/not-specified-1454671.jpg
The davit had an old 1500lb winch on it so I replaced it with a champion 3000lb winch from amazon and replaced the 3x4 stainless backer plate with a 9x19 1/2 aluminum plate to take some stress off the back wall of the boat.
After only 9 months the clutch failed Dropping my tender 3 feet and then dropping the winch into the salt water. I am going to replace the winch but I am not sure what to buy. Does anyone have any a suggestion on what I should buy and what size?
I called Warn and they told me I need to buy a hoist not a winch but that seems wrong. Any advice would be appreciated.
Thanks,
Russ
Thanks,
Russ
