Page 1 of 2
ac Freon refill
Posted: July 26th, 2021, 1:44 pm
by pepmyster
Hello to all!!!!! I had a problem which was answered to the cause of one of my ac units frosting up. The logical solution was that it was low on Freon, ( thanks Hans). Has anyone done this to their units? I found the the service port which was labeled "suction". Makes sense. If you have done this, what did you use as a product? I'm almost sure it's R12. Thanks in advance.
Re: ac Freon refill
Posted: July 26th, 2021, 1:56 pm
by tomschauer
Depending on the years its either r-22 or r-410a.
It should have a label stating the refrigerant type and the charge weight.
Re: ac Freon refill
Posted: July 26th, 2021, 1:58 pm
by g36
You must make sure what refrigerant is in the unit. There should be a label for kind and amount it is using.. If you don't have any guages then your just blindly putting it in, which isn't the best option . It can be done but you can also screw it up and can be dangerous ,Also if your low you have leak., if it is r12 its pretty expensive now if you can find it.
Re: ac Freon refill
by buster53
Before doing anything, you need to BE Sure, not almost sure.
Re: ac Freon refill
Posted: July 26th, 2021, 1:59 pm
by pepmyster
2004, You could be right about the R22. I read a lot and many have written that it was R22.
Re: ac Freon refill
Posted: July 26th, 2021, 2:15 pm
by tomschauer
Its definitely not R-12.
For 2004 it should be 410a, but could still be 22.
22 is quite expensive now. About $35 a pound wholesale.
So if its low, you want to find and repair the leak, not just juice it up.
Re: ac Freon refill
Posted: July 26th, 2021, 2:20 pm
by pepmyster
I get that. It must be missing just enough Freon to frost. It working but frosts. After all those years, not surprised it missing a bit.
Re: ac Freon refill
Posted: July 26th, 2021, 2:25 pm
by tomschauer
Low airflow will also make it frost.
Dirty coil etc.
Re: ac Freon refill
Posted: July 26th, 2021, 2:27 pm
by pepmyster
I cleaned the condenser, air filter. checked the fins. I put a fan directed at it also, same result.
Re: ac Freon refill
Posted: July 26th, 2021, 2:45 pm
^^^THIS.
I've had a lot of spirited "discussions" with folks on this topic. If you're passing enough 80F air over something, it CAN'T freeze. Something must be restricting the flow somewhere for the evap to even get close to freezing temperatures.
Low pressures in the system will lower both the condensor and evap temperatures, but if the evap coils have enough flow over them the refridgerant will absorb all the BTUs they need to get the temps over freezing VERY quickly. There may be portions of the evap coils that don't get flow that get cold and establish frost or ice, but that should never grow over the rest of the coil if there is enough return air flow.
