Breaker Replacement
Posted: May 10th, 2022, 4:16 pm
by Postmaan
My AC #2 on a Carver 355 keeps tripping the breaker switch. Does anyone know how to replace the breaker? Looks easy but not completely sure.
Re: Breaker Replacement
Posted: May 10th, 2022, 9:25 pm
by tomschauer
Do you have an amp probe? it's possible the breaker is bad, but more than likely an issue with the a/c unit.
Posted: May 10th, 2022, 10:51 pm
by tomschauer
Hey, another idea is to disconnect your a/c power into the panel. Move the wire from the a/c unit that is tripping the braker to the other a/c unit breaker. reconnect the a/c. If it trips that one, you can pretty much be sure it's the a/c unit not the breaker.
Posted: July 20th, 2022, 10:00 pm
by Postmaan
Thanks for the suggestion. Original unit and after following your advice I believe it’s done. Installing a new AC unit.
