Page 2 of 3
Re: Boat listing to port
Posted: May 10th, 2014, 9:25 pm
by Lyndon670
Also, you have the tank equalizing valve to equal both tanks out. Open the valve and gravity will allow the tanks to flow into one another until they are both at the same level. I highly doubt that this is vausing the boat to list this much - unless you keep forgetting to add diesel to the one tank! You would have to have one tank with double the amount of the oppostite.
Posted: May 11th, 2014, 6:27 pm
by waybomb
Coring could also be saturated above the water line from leaking penatrations above the water line.
Posted: May 11th, 2014, 10:11 pm
by Lyndon670
You are suggesting that the core soaked above the water line would be enough to cause the boat to list ??? C'mon.....perhaps there is too many ice cubes in the left side of the ice maker...
Posted: May 13th, 2014, 9:08 am
by aives
Lyndon
Re grey water, does yours drain directly out of the boat? Go to a holding tank and then pumped out? After winterizing, now that boat is back in the water , we seem to be holding grey water, is there a sea cock that should be opened? If so where is it?
Have asked many here and not found anyone who knows!
Tks
Posted: May 13th, 2014, 10:43 am
by Lyndon670
I believe the grey water pumps to the front shower sump(s), but I can check for you when I get back down to the boat. There is now seacock to open - it will pump above the water line. The front head(s) and vanity(s) will join together and with go I to the sump or straight over - but I will check.
Why do you think you are holding grey?
Posted: May 14th, 2014, 11:25 am
by aives
Lyndon670 wrote:I believe the grey water pumps to the front shower sump(s), but I can check for you when I get back down to the boat. There is now seacock to open - it will pump above the water line. The front head(s) and vanity(s) will join together and with go I to the sump or straight over - but I will check.
On a routine bilge check I noticed fairy clear but pinkish water in the bilge. Not much water but pink and I thought the aft shower was leaking. there is a holding tank around the sump and it was completely full. I then checked the front sump and it was at least three quarters full.Ww have been aboard since April15 and I am concerned where all the water has gone to. I have checked all through the engine room and no moisture.
Maybe I just need to replace sumps. Front sump had tripped electrical but once I emptied all water it has stayed on. Will watch what happens today with regular use.
Posted: May 14th, 2014, 6:44 pm
by Lyndon670
did you try to manually engage the pump in the sump? Could just be the float with grime on it...boiling hot water and straigt spray nine poured into the box should clean it up.
Posted: August 26th, 2014, 9:20 am
by PCOMT
Did you solve this?
FWIW, I had a small list to port that I believe was caused by fresh water tanks. The fill is on the port side and the starboard tank is filled via a tee in the port fill line. The trouble was the starboard fill line was routed high and it seemed to air lock. The starboard tank did not fill up, it stayed almost empty. It would eventually level out as the pump suctions were also tee's, but that took a while. Until it leveled out, I had a small list to port.
I don't know if this would apply to your boat, But....
Posted: September 26th, 2014, 2:10 pm
by trmnewt
Not really on topic, but I also have a 506, and I am tyring to locate the shower/AC sumps. Does anyone know where they are on this boat?
Posted: September 26th, 2014, 2:12 pm
by Lyndon670
They are located under the floor in your master. Depending on what hull number you have, will either be in the bilge or access under the mattress.
