Acrylic sliding door maintenance on Carver 355
Posted: June 8th, 2024, 5:16 pm
I finally got tired of my salon door. It was so hard to open and close.
I took the bottom track apart and cleaned it. I’m going to lube with a plastic silicone lube. Then I will put it back.
It was relatively easy to remove the bottom track. I removed the 3 Phillips screws from the bottom of the door. This released the sliding part of the track from the door. I then removed the 4 screws holding the track to the boat. I had to slide the door to get to all 4 screws. Then I pried gently to release the gasket from the track.
It was filthy. I vacuumed the slot the door rides in, then took the track to the sink and washed it with soap and water.
Now off to the store to find some lube.
