Vinyl wall covering?
Posted: July 15th, 2024, 12:12 pm
Re: 1996 Carver 325
It appears that when Carver finished the interior of our boats many places were covered with a textured vinyl product that is foam backed, and it was glued to the fiberglass surface being covered. I have a couple spots where it appears the foam backing has deteriorated...more like disintegrated, causing the vinyl to come lose and hang down or fall off the wall. Has anyone else had to deal with this? If so, any thoughts on how to best correct the problem?
Attacked is a picture of he side window in the aft-cabin. As you can see the foam backing has crumbled and the attached vinyl starts to fall off the wall. My thought is to scrape the crumbling foam off the vinyl and wall as clean as possible and use spray adhesive to re attach the vinyl. Just so you know, it is not from being wet or leaks. I'm guessing what to do, and welcome input from others, please?
Thanks.
Thanks.
