Shower Sump Not Working
Posted: July 20th, 2024, 8:00 pm
I was digging into another issue on the boat today and discovered the shower sump isn’t working.
What’s the best way to troubleshoot the switch and pump? I’m assuming drain the water out of the box and then activate the float switch with the breaker on and a multimeter on the wires going to the pump to see if the switch is supplying 12v? If yes, then pump is bad, if no, then switch is bad. If the switch is bad, then direct wire the pump to make sure the switch and pump haven’t both gone bad? Do I have that all right?
Does anyone know how to activate these “automatic” Rule switches that are a fully enclosed unit? The standard manual float switches are obvious but I can’t tell by looking at this one. Is there some sort of float inside that I can lift up by sticking something in there through the openings in the side? I googled it and watched a couple product videos from Rule but no luck.
er
