Page 2 of 2
Re: Carver 355 sliding door - difficult to slide
Posted: July 15th, 2014, 10:54 pm
by Reelpriority
The spray lubricant does not track into the cabin. I used it on a previous Carver which also had a rough sliding door. The product works and is certainly a much lower cost alternative to rebuilding the door tracks.
Posted: September 22nd, 2021, 8:33 am
by Jrr7885
I have the same problem with the sliding door for years I just found a spray at menards called Blaster dry lube with Teflon I was also missing a screw and nut on the bottom replaced it and the door now can be slid now with 1 finger and it is dry lube and doesn’t track in the cabin wish I tried this years ago but it works great now
Posted: September 22nd, 2021, 6:15 pm
by tomschauer
Clean, clean, clean the tracks!!
Then use a dry silicone or teflon lubricant sparingly.
I've found the key is to keep the tracks clean. All dust and dirt seems to find its way in there. If you use to much or the wrong lubricant, it just traps more dirt and makes it worse very quickly.
Posted: September 22nd, 2021, 6:53 pm
by uchu
tomschauer wrote:Source of the post Clean, clean, clean the tracks!!
^^This^^. Cleaning is step one. Then I used 3 in1 silicone spray and no problems afterwards.
