How do I replace fly wire ona porthole?
Posted: October 25th, 2014, 9:54 pm
by PNGTaubada
Hi. 1 have a 466 and the fly wire is damaged on the aft port windows, I unscrewed all of the screws to see if the frame easily comes off and it doesn't. The inside rubber seal seems glued and I don't want to damage this. Any help on The correct way to do this would be appreciated. , line in PNG so parts are not redily accessible.
Re: How do I replace fly wire ona porthole?
Posted: March 8th, 2015, 9:37 am
by PNGTaubada
I still haven't found a solution to this ... surely there must be a simple way of replacing the fly wire on the port holes?
Posted: March 8th, 2015, 10:08 am
by Ramsport47
By flywire, I'm assuming you mean screen. There is a replacement kit available thru Carver for these that includes a new seal. The brand of porthole is Schmitt (spelling may be wrong), but if you call Carver with your Hull number, they will either be able to sell you replacements or direct you to where you can get them.
Posted: April 22nd, 2015, 10:38 pm
by PNGTaubada
Thanks for the advice! I will do that, although I'm in PNG - I assume they can freight it over ...
