Engine Temp Alarm
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Engine Temp Alarm
Postby SanJuanDreamer » June 15th, 2017, 11:13 am
I have a 98 Mariner with Crusader 454xi.
Has anyone added an aftermarket temp alarm to their engines?
Looking to install temp alarm for the engines but not sure where to install the sensor.
Re: Engine Temp Alarm
Postby Viper » June 15th, 2017, 6:35 pm
Get the kind that mount to the exhaust hoses. They're an easy install. Short of that, an inline water pressure sensor can be used so that as soon as raw water stops, the alarm will sound but the exhaust alarms are simple units that will sound off before you even know at the helm temp gauge that there's a problem.
SanJuanDreamer
Postby SanJuanDreamer » June 15th, 2017, 11:38 pm
Think I found one but the sensor cable isn't long enough.
I emailed them to see if they have a 4oft.
http://www.ebay.com/itm/FAHRENHEIT-TEMP ... 2163457512
Postby km1125 » June 16th, 2017, 7:55 am
SanJuanDreamer wrote:Source of the post Think I found one but the sensor cable isn't long enough.
You can extend those lines with any good-quality duplex wire. Your reading might be a slight fraction off, but for alarm purposes it's not going to matter.
Postby Viper » June 16th, 2017, 9:33 pm
This is more like what I was talking about. It's specifically designed to be clamped on to the exhaust hose. If you contact them, I'm sure they can put a unit together for you with the length of cable you need.
http://aqualarm.net/exhaust-engine-monitors-c-5/20248-exhaust-overheat-alarm-kit-twin-p-12.html?zenid=16d8bff57883363b91452facd873a2ae
SanJuanDreamer
Postby SanJuanDreamer » June 16th, 2017, 10:35 pm
I'm somewhat confused...why would I monitor exhaust temp and not engine\coolant temp?
The reason I'm looking is because the engine antifreeze\water pump belt broke and the engine got above 240 before I noticed it. Caused some damage but I got lucky. If I had an alarm, could have been better.
Been thanked: 490 times
Postby waybomb » June 17th, 2017, 7:47 am
The coolant water goes out the exhaust.
You will notice the temperature deviation much quicker there.
Postby Viper » June 17th, 2017, 9:40 am
When raw water delivery fails for whatever reason, your exhaust will get hot immediately after the water stops flowing. This will happen before your engine temp or any alarm for engine temp identifies there's a problem. By that time, you could be melting fiberglass exhaust tees, etc.
Just had an overheat go terribly wrong because of this. Melted a tee and stopped the engine while underway at high rpm before the owner realized there was a problem. If there were exhaust sensors, it would have audibly alerted right away before the engine got too hot. The engine is toast!
You still need to monitor engine temps for obvious reasons but for raw water failure alerts, raw water intake or exhaust monitoring are the best methods of alerting immediately that there's a problem.
Postby km1125 » June 17th, 2017, 12:20 pm
Two completely different issues that could cause a problem. The OP's post is about the circulation pump failing, which causes head temperature to exceed specs and cause issues. In that case, the raw water is still flowing to exhaust and exhaust is still very cool.. and probably would not set alarm even if equipped.
The engine coolant temp alarm would have caught that issue but would not likely catch a raw-water-flow problem caused by a bad impeller, partially plugged exhanger, partially plugged intake, etc until it might be too late. The exhaust temp can climb much quicker than the engine temp and could cause exhaust hoses to burst or catch on fire. ( I had one burst just like that)
You really need both to catch the problems either way before any damage occurs.
Postby Viper » June 17th, 2017, 1:20 pm
SanJuanDreamer wrote:Source of the post.....The reason I'm looking is because the engine antifreeze\water pump belt broke and the engine got above 240 before I noticed it......
You didn't mention that in your first post. That's why you have your gauges, to monitor engine temp. If your app doesn't have an audible alarm to alert you when you're not looking at your temp gauge, you should install one.
km1125 wrote:Source of the post Two completely different issues that could cause a problem. The OP's post is about the circulation pump failing, which causes head temperature to exceed specs and cause issues. In that case, the raw water is still flowing to exhaust and exhaust is still very cool.. and probably would not set alarm even if equipped.
That's why I mentioned you should have both monitoring systems
