Fuel sender mystery
- Carverlvr2
- Been thanked: 22 times
Fuel sender mystery
- Has thanked: 467 times
- Been thanked: 1763 times
Re: Fuel sender mystery
I'd look for poor or corroded connections for the gauge. If you've checked the back of the gauge and all looks good, find the bridge harness plugs and check for good clean contact pins. Other than that the readings may in fact be lower for various reasons or the gauge is on its way out. Swap the gauges from one side to the other and see if the same readings follow the gauges. That'll tell you if it's a gauge issue, accurate readings, sender or wiring issue.
BTW, the sender gasket looks like it's seen better days and may be leaking. You may want to confirm whether it's leaking or not. You can buy replacement gaskets for those senders.
- Carverlvr2
