Temp gauge barely moving - sender or gauge ?
Posted: July 9th, 2017, 10:14 pm
We have a 1982 mariner with crusader 350's and the starboard temp gauge barely moves. When we are heading out it shows around 100 degrees and the temp on the engine using a temperature gun is 130 - 140. I tried swapping the sender wires from port and starboard , when I did that the issue stayed with the starboard gauge. Is swapping the wire at the engine side sufficient to test the gauge ? or should I really pull both out and swap them at the bridge ?
Thanks in advance
Thanks in advance
