Rudder water leak
Posted: July 16th, 2018, 8:22 am
by pepmyster
Hi guys! I noticed water around the shaft of the starboard rudder shaft. Port side is dry as a bone. Anyone have this happen? 360 Sport Sedan.
Thanks in advance, Andrew
Re: Rudder water leak
Posted: July 16th, 2018, 8:32 am
Normal, maybe packing needs a small adjustment.
Posted: July 16th, 2018, 10:02 am
by pepmyster
Like tightening? Can I do this on the water?
Posted: July 16th, 2018, 12:28 pm
Yes you can if you can get to it ..
....google it and watch someone do this if you have never done this before.....have a look in your manual, there should be a drawing of the rudder parts, from that you can see the locknut and how it works....loosen lock nut ,tighten one flat, re-lock and see what happens.....the procedure I have used on packing is generally to loosen till it leaks to flush it then re tighten till you are happy. Good luck man.
Posted: July 16th, 2018, 12:30 pm
by g36
Posted at same time
yes tightening and it can be done on t h e water. search for a Youtube video it may help you visualize the packing nuts and how to tighten them.
Posted: July 16th, 2018, 8:35 pm
by pepmyster
Thanks guys, did some searching, I understamd better the concept. I will try the tightening . but, for sure they probably need the new packing. No a major amount of water, but I love the look of a clean engine room.
