exhaust outlet for generator
Posted: November 29th, 2015, 7:44 am
by scoobychonx
Hi can anyone tell me where there generator exhaust exits. Just trying to find the best position. Regards lee
Posted: November 29th, 2015, 4:15 pm
by After Taxes
Doing a new install?
Posted: November 29th, 2015, 5:06 pm
by scoobychonx
Yes it's a new install and just wanting to get ideas. Regards
Posted: November 29th, 2015, 9:53 pm
Out either side or the stern. I'd say in a new install, out either side is likely the easiest as you don't have to try and run the exhaust hose through the aft cabin. Are you doing this yourself or hiring someone? A lot of things to consider.
Posted: November 30th, 2015, 4:38 am
by scoobychonx
Hi thanks for the info. I'm going to fit it myself as I'm an engineer
Posted: November 30th, 2015, 7:06 am
by CYO Admin
Look into doing an underwater exhaust system. You'll thank me later :)
Posted: November 30th, 2015, 5:06 pm
by scoobychonx
Does the underwater exhaust system make a big difference in silencing
Posted: December 1st, 2015, 6:33 am
by CYO Admin
scoobychonx wrote:Source of the post Does the underwater exhaust system make a big difference in silencing
Yes it does. The water is discharged under the water line and the exhaust is above the water line. Makes a big difference in the noise level.
Posted: December 1st, 2015, 6:55 pm
scoobychonx wrote:Source of the post Hi thanks for the info. I'm going to fit it myself as I'm an engineer
Will this be a new or used marine unit, and do you have full installation instructions for that model?
