SEI outdrives
Posted: August 16th, 2016, 12:01 am
by Paul
Hello all. I have purchased an 88 270 Montego dual cabin. We have been doing a lot of work on her are anxiously awaiting her first launch ( under new management). Unfortunately she has not been serviced properly for a good while it seems. I had requested new impellers, bellows kits and gimble bearings be installed by our boatyard. The service on the port side went smoothly and that unit is ready to install. The starboard unit is another matter. It is frozen up to the point it must be replaced. The Alpha one 1.84 gearing has been discontinued and the recommendation by the yard is to replace both units with 1.94 SEI drives. Price is very reasonable compared to rebuilt Alpha ones. Has anyone in the forum got any experience with these outdrives. I understand they are assembled in Florida using some components from south east Asia. ANY input would be appreciated.
Re: SEI outdrives
Posted: August 16th, 2016, 5:14 am
by mjk1040
Paul, why not just look for a used unit for the starboard side. I am sure there must be one out there somewhere, since you have invested so much already in the port unit. Mike
Re: SEI outdrives
Posted: August 16th, 2016, 7:13 am
Re: SEI outdrives
Posted: August 16th, 2016, 8:28 am
by tomschauer
Several years ago I replaced the gen 1 alphas on my Montego with the SEI drives (both upper and lower units), I had no issue for the remaining two years I owned the boat.
Last year a friend at our marina replaced his single gen 1 with and SEI drive. It failed after 12 hours and he followed the break in instructions and logged all time and rpm ( I did not follow the break in procedure). The replacement also failed the same season. The third drive is working well.
Good point is they sent replacements within about 3days for each failure, no problem. Bad news is lost time replacing the drives. I have heard both types of similar experience from others, failed drive but good replacement service.
I would make sure the marina will cover any labor warranty if they need to be replaced. I believe they carry a full two year replacement warranty.
Tom
Re: SEI outdrives
Posted: August 16th, 2016, 12:53 pm
by Paul
Thanks for all the input fellas. I'm squeamish about a used outdrive ( I already have two). SEI warranty is three years for any reason. Impact, run out of oil or you name it. Not completely sold on AM parts but you can't beat that warranty.
