Page 1 of 2
Oil capacity for Volvo TAMD 74EDC
Posted: March 15th, 2018, 8:13 pm
by Makin Waves
I can't seem to find the oil capacity for my boat engines, 2006 Carver 46MY
2006 Volvo TAMD74EDC
I was sick in the fall and didn't change the oil, I want to do it this spring, also I have never used automatic oil change system, this boat has one
thanks
Dave
Re: Oil capacity for Volvo TAMD 74EDC
Posted: March 15th, 2018, 11:15 pm
by tomschauer
Dave, if you read full on the sticks, drain one engine and replace the same amount you pull out. That should get you really close, then just add for the filter, run and top off if needed.
Posted: March 16th, 2018, 8:15 am
by Midnightsun
Pretty sure this covers yours. 6.2 US gallons.
EDIT: Can't seem to find the link anymore however I do have a manual that I downloaded. PM me your email and I will send it to you.
Posted: March 17th, 2018, 3:43 pm
by mjk1040
Sounds like u need 3-5gallon pails of Rottella T 15W40!
Posted: March 17th, 2018, 4:15 pm
by Makin Waves
3 pails of Rottella T is what I was figuring on, going to change the gen oil as well, looking forward to trying the auto oil changer, should be interesting
Posted: March 17th, 2018, 6:00 pm
by Midnightsun
Makin Waves wrote:Source of the post 3 pails of Rottella T is what I was figuring on, going to change the gen oil as well, looking forward to trying the auto oil changer, should be interesting
You are really going to like the oil changer, makes the change so much easier. I bring a couple of 5g empty jerry jugs with me. Insert the tube end of the oil changer and pump out the oil. Then simply reverse the switch and put the tube into the new oil pail pumping it into the engine.
Posted: March 17th, 2018, 6:59 pm
by Makin Waves
Thanks, should be a piece of cake, I'm having the marina change the fuel filters and racor filters, one drop of spilled diesel will haunt me all summer
Posted: March 17th, 2018, 8:23 pm
That oil changer is one thing I would dearly like to install.......I am jealous.......
Posted: March 18th, 2018, 4:50 am
by mjk1040
Filter change is not that bad. U just need some oil absorbent pads and some HD large easy zip lock bags. Loosen filter, place a zip lock bag over it and spin it off into the bag. There are some great odor removal sprays out there, One called Zero Odor works great.
Posted: March 19th, 2018, 7:21 pm
by Makin Waves
mjk1040 wrote:Source of the post Filter change is not that bad. U just need some oil absorbent pads and some HD large easy zip lock bags. Loosen filter, place a zip lock bag over it and spin it off into the bag. There are some great odor removal sprays out there, One called Zero Odor works great.
Thanks but I think I will leave that nasty job to them
Dave
