Impellor replacement on 456 port engine
Posted: August 12th, 2022, 8:31 am
by Bakoboat
Does anyone know the best way to access impellor on port engine (cummins 450 diamond series). (456 motor yacht). Starboard is easy and very accessible but port is away from walkway between engines. Thinking of removing cover off belt and accessing from front of engine.
Re: Impellor replacement on 456 port engine
Posted: August 12th, 2022, 8:43 am
Can't answer your access question, but I have a question for you. Do your impellers have the threaded insert? What model impellers are they?
Posted: September 15th, 2022, 10:16 pm
by mjmason1
I found it easier to remove the water pump from the port side then work on the impellor between the engines. I bought a couple of bolts to remove the impellors.
