Volvo Penta 7.4L needed ASAP
- pitshop
- Vessel Info: 2000 350 Mariner
- Has thanked: 2 times
- Been thanked: 2 times
Thanks in advance,
Skip Williams
Charleston, SC area
- Has thanked: 314 times
- Been thanked: 585 times
Re: Volvo Penta 7.4L needed ASAP
You may want to look at the other motor also. These should provide 1000 hours or more if properly maintained and not pushed to the limit all the time. Check the oil, etc. Possibly lack of maintenance or water intrusion?
- mjk1040
- Been thanked: 237 times
- Has thanked: 432 times
- Been thanked: 1599 times
Find out what caused the failure. If it was due to an OEM defect, contact Volvo. They may help through good will.
What is the serial number of the block that failed?
When they stop making blocks, you will see a core charge for rebuilds.
- pitshop
- pitshop
Viper wrote:Source of the post GM stopped making 7.4L blocks a while ago but they are still a dime a dozen. Anything "New" will be new old stock. Make sure you get the same generation/build/spec so you have a balanced pair/output.
The serial number is unknown (suspicious sounding, huh?) During the survey, the surveyor did not find the tag and put down "Unknown". Monday, I was digging thru all the paperwork that was left on the boat and discovered what I THINK is the serial number for the PREVIOUS engine, before this one was replaced in 2008. It is 4012022461-3860936. Have no idea if that is for the current engine. Local Volvo dealer said that one was never registered with Volvo.
The serial number will tell.
- pitshop
tomschauer wrote:Source of the post You don't need to use a Volvo block. They buy them from GM and marinize them. All of your Volvo gear will "bolt" on to the new or remanufactured long block. You do want to make certain you use the same series long block. Yours should be the Vortec roller motors, unless someone cheaped out when they last replaced them.
Any idea where to find a serial number, if the tag on the side is no longer legible? I cannot trust the documentation on board, at this point!
Users browsing this forum: No registered users and 46 guests
