waybomb wrote:Source of the post..... Runaway's happen.....I've seen it. Pretty damn scary.
+++1
waybomb wrote:Source of the post Sounds as if you have things covered.
Something you may want to consider. Develop a way to completely block the air intake to the engine. Runaway's happen. Center bearing seal goes bad in the turbo, engine oil gets in the intake stream, and bam - it's running away from you. Only way to kill it is to completely block the airflow. Completely.
waybomb wrote:Source of the post How many cubic inches is the engine, how many rpm is it running at runaway, how much does the bottle hold, and finally, if the engine is still spinning when you run out of suppressant, it may light off again and off it goes.
