Carver 26 Santa Cruz 2667 Questions
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
Re: Carver 26 Santa Cruz 2667 Questions
- Eggbert
- Vessel Info: 1985 Carver Santa Cruz 2667
- Has thanked: 4 times
- Been thanked: 12 times
I sort of suspect the more it rolls, the more the force to return to upright will increase. To a point. It’s really not feasible to find the angle of ultimate stability without high risk.
Anyway, if it achieves nothing more than making me feel better, I’ll enjoy the physiological piece of mind!
When I first saw the boat it was out of the water and I suspected at that time it would be tippy however the owner played that down quite a bit. He was partially right, but when it does heel, it’s often very unexpected and on the bridge, it feels downright scary.
On the speed, I never had any intention of humming along at max throttle on any sort of future basis. I just wanted to see what it would do. If I remember correctly, I sort of bumped the max speed up to 40, but it may have been more like 38 to 39. This was based on a waterwheel based speedometer, which may not be that accurate. Calculations from charts indicate a max. speed to be 37.4 mph, so it’s in that range somewhere. I don’t think I’ve ever had it over 20 mph since then.
I have had it out in open ocean a few times and one time was quite bad, although the boat handled it quite well. I had everybody down below as I didn’t want weight up top, but mainly because if anyone fell overboard I couldn’t turn around to get them. I would have tried though, and that would likely have been the end of boat and passengers considering the rocky coastline. Hmmm…. I should have known considering the water was like a mirror on the way out…. The calm before the storm. Front third of the boat coming clear and the bow pulpit tip just skimming the water on the next wave. Wipers going due to spray and once home, I noticed the whole boat coated in a layer of salt.
Turning back up the river wasn’t much fun due to a following sea, but wasn’t terribly bad.
I really like my boat for a whole lot of reasons… I just don’t trust it 100% yet.
As for the structure, the hull is solid fibreglass but the transom has a wood core which I think is plywood. You can kind of see it with the exhaust removed. Everything is sealed tightly outside, but is a bit open to bilge water inside. As far as I can tell, it’s still solid though.
Thank-you for your post.
- Cooler
- Been thanked: 601 times
- Eggbert
tomschauer wrote:Source of the post Eggbert, if it didn't tip over in the first 33 years of its life, I would think with reasonable loading you should be good!
LOL.... I think I'd add "rap on wood" or respond with "famous last words"... remember the Bounty? 1960 to 2012 R.I.P.
I do agree though. I've only had a few incidents over the years and only one that truly scared me, although much of that was due to surprise. Open ocean, heading back in. Following sea. Trying to stay on back of wave, but accidently over-ran it. Surfing down other side boat tipped crazily, had to grab a rail, managed to throttle back, and boat came back to upright.
Since this older thread has been resurrected, I think it's worth showing a pic I just snapped this morning. The white spots are due to a few flurries.
Note the small area of the hull under the blue lines (which is where the boat sits when in the water). Of course, from the stern it looks fine, but from this angle you can see why I thought it might be tippy.
- Has thanked: 598 times
- Been thanked: 1281 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
2022 Stingray 182 SC
- Has thanked: 78 times
- Been thanked: 1093 times
Eggbert wrote:Source of the post
I think the bigger issue with the area under the blue line is the beam measurement there. Compare that to the actual beam of the boat, and it looks 3-4' less!!
Maybe it's just the angle of the picture though.
- Eggbert
So, I thought I better add a few more pics. Below is a view so you can see how the hull transitions bow to stern. The waterline meets the chine just at the front tie-down strap.
Here's a pic of the stern where you can see the 18degree dead-rise plus you can see where the waterline is as the lower ends of the two center swim platform supports have some barnacles on them.
Finally, you can (sort of) see how high she floats (compared to the bottom paint) in the following picture.
- Rweiss25
- Vessel Info: Carver Santa Cruz 2660
