Tri-Data failure
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
Tri-Data failure
Thanks for any suggestions other then lifting out of the water.
Re: Tri-Data failure
What other electronics and their models do you have on board? This helps determine how the ducer is hooked up and may help in the diagnosis if it's more than just a fouled paddle wheel. I suspect the ducer is hooked up to a DSM and then the data branches off from there to other devices. I'm assuming it's not a NMEA 2000 unit, do you know if it's hooked up to a NMEA 0183 or Seatalk network?
- Agriman
- Been thanked: 490 times
If no dummy plug, have somebody close by to put their hand over the hole while you clean the wheel.
waybomb wrote:Source of the post The wheel module may be removable from the inside. If you see a pin going through a nut like device on top, pull the pin and unscrew the nut.You may even find the dummy plug nearby on a short cable.
Good call Fred, I forgot about that.
- Agriman
- Has thanked: 602 times
Agriman wrote:Source of the post Wow, thanks Fred, I always wondered what that tube shaped plug on a cable was for. Does the wheel simply pop out after removing the pin and nut? Is there a gasket or o-ring that might need replacement? I'm worried I should wait until the boat gets pulled out.
There are some of videos on u tube of how to get that thing apart and plug the tube , clean and put back together......if yours is where mine is the access with both hands will be the issue......good luck man...
There should be a couple of o-rings on the blank. You could use those to replace the ones on the ducer if you have to.
