454XLi exhaust manifold replacement 96 Carver 400
Re: 454XLi exhaust manifold replacement 96 Carver 400
Postby km1125 » July 11th, 2019, 12:17 pm
You sure that's rounded off?? Looks like a 12 point bolt to me
Postby km1125 » July 11th, 2019, 12:31 pm
With only one left you can also take the plugs out and stuff each hole with a rubber stopper or wadd of paper towel so nothing drops in. You can then break the manifold loose on the far side from the bolt and have someone rotate it around the stuck bolt while you put tension on the stuck bolt to break it free. Just moving the manifold up and down about 1/2 inch is all you need to help things along.
hausherrs
Vessel Info: 1996 Carver 400
Has thanked: 5 times
Been thanked: 10 times
Postby hausherrs » July 11th, 2019, 1:47 pm
Thats an idea... I thought of trying to rotate the manifold, just a little. Its pulling away at cyl #1. There is a 1/8 gap, maybe 1/16, you can put a flat tip screwdriver in between. Again this is cyl #5.
It is a 12pt but the all the "points" are rusted off or rounded. I also thinking about tapping a smaller socket on there and trying to get an impact on there. Or get an Irwin bolt extractor and put it on the impact.
Anyway, i have to get an arsenal together, plan A, B, C, and D......
A) Wiggle manifold
B) Tap on socket and try the impact, If not, try breaker bar
C) Irwin bot extractor
D) Air hammer the bolt out. If that dosent work just cut the head off..
Postby bud37 » July 11th, 2019, 2:32 pm
That may be an ARP exhaust bolt...they are hardened........So I am not there, but just be careful prying on that bolt with the manifold........the head can be cracked around the bolt hole area easier than you think.....bolt extractor first.......again good luck and take your time.
Postby km1125 » July 11th, 2019, 3:46 pm
Also, not sure what size that is, but you might try a 12 point metric that is just a bit smaller and tapping that on there.
I would not pry on the manifold, just pivot it at the bolt back and forth.
Postby bud37 » July 12th, 2019, 10:30 am
hausherrs wrote:Source of the post Thats an idea... I thought of trying to rotate the manifold, just a little. Its pulling away at cyl #1. There is a 1/8 gap, maybe 1/16, you can put a flat tip screwdriver in between. Again this is cyl #5.
A) Wiggle manifold
If it were me I would get myself a complete new set of exhaust bolts before installing the new manifold assembly....no telling what abuse the current set has gone thru....
hausherrs
Postby hausherrs » July 12th, 2019, 11:20 am
bud37 wrote:Source of the post If it were me I would get myself a complete new set of exhaust bolts before installing the new manifold assembly....no telling what abuse the current set has gone thru....
I have all new parts for all 4 manifolds. Gaskets, block off plates, riser bolts, manifold bolts, and water fittings/hoses.
km1125 wrote:Source of the post not sure what size that is, but you might try a 12 point metric
Its a 12pt 3/8in.. So whats smaller then that? 9mm?
Postby km1125 » July 12th, 2019, 1:50 pm
Yes, that would be it... unless you have a 9.25mm socket!
Another thing I've done is sacrifice an old feeler guage, cut it in strips and use it to fill in the 'gaps' in the socket while I tap it on. But I can't imagine trying to do that while upside down and backwards working on a manifold bolt!
Seems like such a small bolthead (and socket) to be putting any appreciable torque on it! I'll have to check my risers. They have 12 pt bolts but I've long forgotten what size they were.
hausherrs
Postby hausherrs » July 12th, 2019, 3:45 pm
My riser had 6pt 9/16in bolts...
Speaking of risers' im still trying to get the one off this manifold with the stuck bolt. I cut the exhaust pipe (Metal reinforced Rubber hose) with my saws-all. That worked amazingly well... That thing is hungry! But the hose was rusted on and now thats clear and a non-issue. The studs on the riser are completely rusted on... I guess it didnt see me bring my air hammer with me. Things are about to get nasty!
hausherrs
Postby hausherrs » July 12th, 2019, 5:27 pm
I know everyone likes pictures....
Progress....
