Manual pump beside gas tank on starboard side
Robby Robb Lewis
Vessel Info: 1986 26 ft Montego
Postby Robby Robb Lewis » April 25th, 2020, 6:20 pm
Hey guys and gals.
Can one of you tell me what the manual pump beside gas tank is for? It looks like it has a thru hull fitting.
Thx
1986 26' Montego :captain: Robby Robb
Craig_B
Has thanked: 144 times
Been thanked: 13 times
Re: Manual pump beside gas tank on starboard side
Postby Craig_B » April 25th, 2020, 6:25 pm
WIthout a picture this is a complete guess but maybe a manual bilge pump?
Robby Robb Lewis
Postby Robby Robb Lewis » April 25th, 2020, 6:27 pm
I thought same but the thru hull is in engine compartment. That would be no use in water. I will take pic tomorrow. Thx for helping.
Robby Robb Lewis
Postby Robby Robb Lewis » May 24th, 2020, 10:15 pm
Can anybody tell me what this pump is used for?
Has thanked: 474 times
Postby Viper » May 25th, 2020, 7:01 am
That looks like a manual gulper pump. Could be used for a number of things but usually in an emergency to pump out the bilge. I've also seen them hooked up to holding tanks for overboard discharge.
Postby bud37 » May 25th, 2020, 8:05 am
Robby Robb Lewis wrote:Source of the post Hey guys and gals.
Thx
Can you see what the other end is attached to, does it have arrows to indicate the flow direction thru the pump ? ?...I was thinking the same as Viper, maybe waste.
Robby Robb Lewis
Postby Robby Robb Lewis » May 25th, 2020, 3:08 pm
Guys thx for responding. I cant see the other end but it does go through the hull in the engine department . Does look like a discharge of the fresh water tank or waste. Does your fresh water discharge have an electric pump? There is another electronic PAR pump in front of it. This exits out the side of the boat.
Robby Robb Lewis
Postby Robby Robb Lewis » May 25th, 2020, 3:21 pm
Cant you use waste pump at sea? ( ten miles out) that means the electric is for waste and the manual pump for fresh water winterization. You all agree?
Robby Robb Lewis
Postby Robby Robb Lewis » May 25th, 2020, 6:17 pm
Problem solved! It is a waste pump out. I crawled under and traced input. It amazing that the waste pump out would be under the boat while underway. I guess a seacock opens and closes it. I would like to thx all responses. Hopefully I can help you guys in future.
Capt Robby Robb
Postby Viper » May 25th, 2020, 9:38 pm
Robby Robb Lewis wrote:Source of the post ....It amazing that the waste pump out would be under the boat while underway....
That's the normal location for waste discharge....through the bottom of the hull.
Users browsing this forum: Google [Bot] and 34 guests
