Generator
- Thepearl87
- Vessel Info: 1987,Carver 3607
- Has thanked: 3 times
Generator
Any ideas???
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Generator
Don't think the cranking relay fuse would cause the genset to quit running, so I'm wondering what else could be common with that fuse.
- Thepearl87
Re: Generator
km1125 wrote:Source of the post Did the fuse actually blow three times and needed to be replaced, or you just replaced it once because it was blown and then a couple times "just in case it was bad"??
The fuse blew 3 times, then did not blow anymore. I'm going to trace wires from that fuse to be sure there are no voids. If I jump the solenoid contacts, the unit turns over well. But no start. I have jumped the low oil wires, as well as the over heat wires also. Now it's above my feable generator knowledge.
- Thepearl87
Re: Generator
Re: Generator
- Thepearl87
Re: Generator
Re: Generator
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Generator
if there’s a way and someone will let me know I can post it on the site here.
“Escape Plan”
Murray, KY
- Thepearl87
Re: Generator
Thanks, I'll print it out when I get it.
I 4hink I have a faulty circuit board. I have it out being tested.
- ColRon
Re: Generator
Thepearl87 wrote:Source of the post thepearleightseven@gmail.com
I have sent the service manual in pdf copy to your email.
“Escape Plan”
Murray, KY
