Hello All!
Been thanked: 470 times
Re: Hello All!
Postby RGrew176 » September 29th, 2022, 12:21 am
km1125 wrote:Source of the post
RGrew176 wrote:Source of the post Welcome Aboard. Best of luck with your Carver. There is most likely a drain plug in there somewhere. I thought my 81 3007 Aft Cabin did not have a drain plug. I did find one in the hull at a low spot where when the boat was out of the water it could drain out if needed.
On my old 3607, the drain plug was at the stern in the bottom between the rudders. The lowest part of the bilge was up in front of the engines, so the only way water would drain would be if the boat was tilted WAY up at the bow. The first couple years I removed the drain plug, but after that figured it was a total waste of time, so I never did after that.
On my 3007 the drain plug was located in the bilge just forward of the engines.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 137 times
Re: Hello All!
Postby KyleR » September 30th, 2022, 10:44 am
Welcome aboard! :captain:
MV Verity
2002 Carver 396
Users browsing this forum: No registered users and 105 guests
