Draining some gas?
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Draining some gas?
Does anyone know if there is a screen/grate at the filler neck on top of the tank? All I can think of ..
Thanks !
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Draining some gas?
- tonyiiiafl
Mine didn't have any valve in that path, but it was an older boat. I'm not sure how a valve would stop something that the cap wouldn't (unless it's a vented cap).
You could just remove a fuel line to the engine(s) and use a small electric pump to pump some fuel into a couple 5 gallon cans, just do all the precautious steps to avoid sparks and spills.
- tonyiiiafl
- Cooler
- Has thanked: 603 times
tonyiiiafl wrote:Source of the post The funny thing is, I know I run 35 gallons out on the way to winter storage. However, this year I was not on my game and ran up to storage with teh tanks set on the aft reserve tank! I will never do that again! I had thought of taking the sender out and running the 25' hose out the aft cabin to siphon, but also concerned it I took that off gas may come out of the hole. It sat at the marina in the water for 3 weeks full and never lost a drop. I could also just ask to be placed in water early April too and leave cap a tad loose to allow some venting, but not too keen with that also with the shrink wrap.
I would get the yard to pull the extra fuel, they have the pumps and hose etc or should. Just give them the fuel containers to fill and you can use it in your vehicles etc.
Chances are the level in the tanks has blocked the airspace below the vent hose take-off area, you could maybe vent it out the fill, just cobble up something to get the fumes outside the shrink but really you don't want raw fuel sitting in the vent hose and possible leaking at some point over the winter IMO.
- tonyiiiafl
