Pulling wires through transom 405 Aft Cabin
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
- Trim Tab Indication at Helm. Currently have Bennett Hydraulic (OEM I guess) Tabs but there’s no indicators at the helm and I just have to guess their position. I’ve researched and know the parts to get.
- Possibly stern thruster. Again, I’ve found the product and parts list.
- Under water lights. Still researching the parts. Recommendations solicited!
- RV100 Transducer that came with my Chartplotter. I have read and will do more research that a transom mounted transducer is ineffective due to Propwash? I don’t fish but since I have the equipment it would be cool to view the 3d products. Any input from you guys would be appreciated. I’ve also read at low speeds the transom mounted transducer is OK? Other articles I’ve read say put a thru hull RV200 in front of the props for full benefit.
ALL of the above modifications require drilling through the transom to run the wires. I’ve done this before on other boats I’ve owned without issue and feel comfortable doing so. However; with this 1998 405 Aft Cabin it appears to be virtually impossible to maneuver the wires through the transom to the area under the Aft Cabin bed area in order to send them to the appropriate location. It looks like the Aft Fuel tank blocks all viewing and access of the transom?
Is there a trade secret to maneuvering that area? My plan is DIY this winter when I pull the boat for inspecting below waterline.
Thanks in advance!
1979 Caravelle 18’
- Been thanked: 654 times
Re: Pulling wires through transom 405 Aft Cabin
And if you're pulling the boat anyways to do the work out of the water, I'd REALLY be pushing for the RV-200 installation as that really would give you full performance. Putting the transducer on the stern will always be some kind of compromise in performance.
- Mikwallace
g36 wrote:Source of the post As you see the aft fuel tanks are in the way. Fishing wires through the area is not a big deal ………. Ran wires up and out of the water underneath swim platform nearest transom where they enter the boat all Sealed and water tight I've had no issues since.
Did you enter wires through the transom or swim platform? At center-line or offset to one side? Did you make stainless steel brackets to mount lights to trim tabs? Your method sounds easier than trying to fish wires around the fuel tank. There’s just not much wiggle room!
1979 Caravelle 18’
- Mikwallace
km1125 wrote:Source of the post When you do it, definitely take some pictures and/or draw up some diagrams as I'm sure future members would appreciate it! I'd also be curious to see what you find and figure out. I've not been inside one of those so I'm curious, but I've heard access is definitely a challenge.
Most definitely will take pics. Just looked at $$$ of RV-200 and removed it from consideration in my plan. I’m sure it’d be great and provide excellent view; however, I’ll use those $$$ elsewhere.
1979 Caravelle 18’
Mikwallace wrote:Source of the post
If you sell the RV-100, it would take one $ off the $$$.
Mikwallace wrote:Source of the postg36 wrote:Source of the post As you see the aft fuel tanks are in the way. Fishing wires through the area is not a big deal ………. Ran wires up and out of the water underneath swim platform nearest transom where they enter the boat all Sealed and water tight I've had no issues since.
I ran the wires up through bottom of swim platform apx above trim tabs. Then on inside they were easy enough to see and grab by removing the access panel in aft cabin headboard on port side and access panel stbd side. Yes stainless plate bolted onto trim tabs.
