1987 36 Mariner - back to life!
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 401 times
Re: 1987 36 Mariner - back to life!
The handle comes out with a long hose, the mount can be adjusted up our down. I did disassemble it and cut the height down a bit.
So we took it out yesterday and the starboard engine sputtered and died a few times and I couldn't get it over about 2000 rpm. Pix below
So today I pulled the carb filetr, clean. Pulled the canister filter, clean. Pulled the anti-siphon valve - completely fouled with a grease like substance. The hose at the fitting also had that mung. Cleaned the valve, cut some hose back, flushed the hose with some carb cleaner, and started the boat up. All is well, but alas, windy and waves. So maybe next week we'll try again.
Pix from the first time out on the lake in about 11 years or so.
And finally the Manitowoc unloading stone. I always wondered how they tied off, and we learned yesterday. There's a boom on the front of the boat. One crew member grabs the line, and they swing him out and down to land. Two crew did this. Awesome. Probably not OSHA compliant!
- Vessel Info: 1986 3607
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 3 times
Steve
Wish me luck. Looks like lots of little balls and other parts are going to fall out.
If anyone has rebuild instructions please forward them on.
Last report was on the Hynautic system - I bought the h50 rebuild kit, and took it all apart and rebuilt it. This time though, bleeding the air out only took 50 turns or so.
The boat has been, running fine, etc. The tachs are screwed up, so I need to replace the gage set. I haven't finished the install on the cabin stereo yet, but that's be done shortly.
Other than that, all is still working and working well.
- Has thanked: 432 times
- Been thanked: 1599 times
OEM Teleflex
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 5 times
- Been thanked: 22 times
