CH 270 Engine rebuild project
- irobertson
- Vessel Info: 1983 Carver Riviera 2807
- Has thanked: 3 times
- Been thanked: 2 times
Re: CH 270 Engine rebuild project
- Has thanked: 602 times
- Been thanked: 1311 times
- irobertson
- waybomb
- CYO Moderator
- Been thanked: 490 times
Id stay with gear drive.
irobertson wrote:Source of the post ....abandon the geared cam drive on the reverse rotation engine, and do timing chains on both.....
WHY?
irobertson wrote:Source of the post Cams and cranks look good. However I'm not planning on reusing the cams. My guy is saying I should abandon the geared cam drive on the reverse rotation engine, and do timing chains on both. I'm inclined to agree with him. He can provide me with a set of matched cams, one LH one RH, and the reverse cam has the distributor gear cut the other way, so the dizzy & oil pump maintain correct rotation. The next step is ordering two sets of .030 over pistons and having them fit to the bores, and having the cranks properly inspected and polished. This is going to be a year long project, taking my time and just going through each step as $$ become available. I also have a list of things that need to be done to the car
Only thing I might ask him, would there be an issue with thrust load direction on the distributor ?.....actually the gear drive is cool, you will never have chain stretch or timing wander and you get that whine lol......
- irobertson
irobertson wrote:Source of the post Thanks for the feedback. I will discuss with him. I did ask about the thrust on the dizzy, but the new pump/dizzy drive gear would be cut at the opposite angle, and the dizzy gear would change, so thrust would still be the same. His position on this may just be his experience, he is a well respected race boat engine builder.
Cool....sounds like you are in good hands there.......keep us posted ... there are no good days if you don't learn something....
